Daves55Sedan
You are using a '57 Radiator in a '55? Can't tell by the pictures, but since the '57/58 radiator is shorter and wider than the '55, you don't have any cooling on the last couple of vertical cooling tubes in the radiator on each side because they are blocked from getting air by the front wall panels.
Also that '57 radiator doesn't look as deep (wide) as the original '55 radiator was. Same amount of cooling capacity, but the '57 radiator made up in width what the '55 had in height. Could be a substantial loss in cooling capacity with this arrangement. But I understand you had problems with space due to the 302 water pump sticking out so far.
Anyway, something to think about.
BTW, nice looking '55 Mainline 2-dr wagon. If it were me, I would put the stainless belt moulding back on around the base of the top, but from a distance, you probably can't tell.
