Ford coupe
When i turn on my left or right signal all four lights flash...How are they grounded as that is a possibility i am told...Grounded just by being bolted to body or??
They are grounded through the light housing to the body sheet metal where they mount. To check if a ground problem, make up some wires with clips and attach to the light housing (bare metal) and to a good ground (bare metal) on the body. Do one at a time, checking it out each time. Could be that one light housing is not making a ground and if that is the problem then this test should find it.
Well that did not give any clue. No obvious suspect. With either signal on, all four lights flash. Sorry, this is a mystery to me.So bot rears light up with park lts on but pass side dimmer than driver side..Both brake lts are on and seem bright enoghThankls
