55 Ford crown victoria part
HenryFord
Omaha
NE
Want to buy for 55 Ford crown victoria only. This is a channel that sits in the upper door way, under the drain gutter. It extends from the windshield back to where the crown crosses the roof. The rubber that seals the side window sits in this channel, and is held in place with 4 screws. They are under the rubber and not visible until the rubber seal is removed. Need left side. Glenn 402-391-4715
Thank you if you can help.
