'55 Ford car turn signal switch wiring
Lamar Wadsworth
Building Ozelle the '55 Ford as a mild custom, using an aftermarket wiring harness from Rebel Wire but keeping the stock column with the stock turn signal switch. Anybody got a shop manual or wiring diagram--I need somebody to identify which wire is which (wire colors) on the turn signal switch. Thanks!
I got a 54 switch wiring diagram which should be the same.
Lamar, This is right out of my 55 manual. I hope you can read it, if not, I can send you a copy. Paul Selfe.
55 ford turn signal colors
brake switch purple or green
r r turn orange/blue
l r turn green/orange
turn flasher blue
r frt turn white/blue
l frt turn green/white
