Daves55Sedan
Had to replace the front crossover brake line and both front wheel cylinders. After re-assembly and bleeding the front brakes, it seems that the passenger side brake shoes are not operating when the brake pedal is depressed.
I bled the front brakes using a mityvac until the amount of fluid I got in the reservoir was exactly the same amount as what was sucked out of the master cylinder thru the lines. Checked for leaks at each connection. All outer surfaces of the lines and hoses are dry as a bone.
I did not bother to bleed the rear brake lines because I didn't think they would have gained an air pocket since I did not disturb them. But if there is an air pocket in the rear section, it seems that it would make sense that only the closest set of shoes to the master cylinder would work.
Any thoughts?
BTW, the old wheel cylinders might have been okay to re-use if I could have gotten a wheel cylinder hone to scrape off a little very minor rust spots in the bore, but nobody has hones anymore. The tool allegedly costs three times as much as one new wheel cylinder. Two places I went to havent had hones for over 20 years. The CXhinese made wheel cyliders have different size brake bleeder screws. That wreaked havoc upon my efforts to fit the mityvac with differnt size hoses.
Any thoughts?
