Steves46
I got a replacement "plug-in" speedometer cable from Carpenter's and since I could not find any guidance in my shop manual as to the correct way to install it, I wanted to see if someone could lend a hand. After I remove the plate that holds the cable connection to the transmission, do I need to remove the gear, insert it into the plug-in and reinsert into the transmission? This is the first cable of this type that I have installed and appreciate any guidance. Thanks.
