Butch's Cool Stuff sells a mount kit but you'll have to modify the trans mount for the AOD per the site.
https://butchscoolstuff.com/54-56-f...mercury-bolt-in-ford-engine-mount-kit-2507cp/
937.260.2451[FONT="]
[/FONT]
[FONT="][/FONT]
info@butchscoolstuff.com Guys that have used their 52-53 kit have found out the hard way Butch needs to update his info I even emailed them pictures to show AOD's line up with the factory cross member,it is the C4 that requires an extension plate. Notice dimension "C" the C4 is 2" further towards the front.
http://non-stoptransmission.com/en/info-ford.php
This kit is for Ford original V8 cars ONLY. See kit #2510-CP if your car was an orig 6-Cyl car or is a Wagon or Sedan Delivery. Bolts in any SB Ford V8 (289-302-351W with C-4, 3spd or 4spd. Other trannys with some modification). Super Good Fit
