Daves55Sedan
To finish this project, here is what needed to be painted with enamel overcoat:
Under the car; inner rockers and attaching floor support gussets and adjacent floor area between the rockers and car frame (both sides of car). Not just the patched areas, all of the entire length of the rockers. Also both rear wheelwells, inner quarter panels and the adjacent floor area between the car frame and inner quarters. (all of this would be metallic blue Dupont Chroma-base enamel).
Inside the car; entire car interior floor and trunk floor including backside of rear fenders in the trunk area. Also, all the doorjambs along with the rain gutter would be sprayed at one time as a unit. (all of this would be metallic blue Dupont Chroma-base enamel).
Car exterior (Ditzler aqua acrylic enamel); Rear portion of both outer rocker panels (under back doors), a portion of right side rear quarter and all of the left side rear quarter under the body side trim, and the car tailpan. Portions of the rear doorjambs at the two-tone separation line would also be painted simultaneously with the adjacent rear quarter panel.
Car exterior (metallic blue Dupont Chroma-base enamel); Front strip along the nose of the hood behind the grille trim strip and a portion of front fender adjacent to front of hood. A portion at top rear of both front fenders above Fairlane trim line. All along the bottom of the trunk lid and several other small areas on the trunk lid.
Overview:
This car came from the factory painted metallic Banner blue poly. It was a very dark blue and was hideous after having been beaten by the elements for decades. I did not like the color and selected the Dupont Chroma-base Atlanta metallic blue back in 1992 for the re-paint. It is a light shade of blue and gives the impression of a silver background with transparent blue overcoat. However, this paint is meant to be used with clearcoat over the enamel. The aqua is a early '90's Ford color somewhat resembling a cross between aquatone blue and seasprite green. This was mixed by a Ditzler distributor back then (now PPG). It is an acrylic enamel. At the time when I painted the car in 1992, I clearcoated the entire car (both colors).
For this project, (summer 2017) I had a couple of aerosol cans of the Dupont Chroma-Base metallic blue which I had planned to use solely for the doorjambs and rain-gutters. The aerosol cans have an activator feature at the bottom of the can which is manually activated immediately prior to using the paint. Once the activator is mixed in the rattle can the paint has a maximum useable life of 12 hours. Thus there would be no messing around once pandoras box was opened, all the spraying had to be done at once, which means every consideration for all the masking and final wiping off surfaces with laquer thinner had to be completely done prior to "popping the tab" at the bottom of the can. I also had a quart can of Chroma-base which would be used for the undercarriage and floor mostly and possibly some other small spots on the car exterior that needed paint patching. I planned to use my new Harbor Freight 6 oz detail gun and my cheap home-made air compressor and air tank assembly for spraying the undercarriage, car floor and trunk floor. I had two aerosol cans of aqua acrylic enamel for the outer rockers, rear quarters and tailpan which would all be done at one time. If I ran out of the spray cans, I also had an old quart of Ditzler the exact same color and a full gallon can of PPG Omni MR186 reducer, but it turned out that it was not needed. I also have two aerosol cans of Dupont clearcoat but do not plan to use them for any of the paint patches.
Dupont "Chroma-base" enamel is an old product and I am not aware if it is as popular as it was years ago. I used it because that is what was used when the car was repainted in 1992. It requires a half-and-half mixture of the base paint with the "activator". The activator comes in different ambient temperature ranges. I had cans of both low and medium temperature activator. I used the medium temp when the painting was being done (during the 90 plus degree temperatures we had this summer [2017] when the humidity was spectacularly LOW.) It was PERFECT weather for painting of this type. There was no breeze, so the garage door was wide open during the spraying. I did not clearcoat over the Chroma-base, since most of the re-paint areas are either under the car, or hidden under floorcoverings, however, this paint is meant to be used with a clearcoat overcoat. Little areas on the exterior of the car that were patch-painted do not appear to match the old paint due to the lack of shine where the new paint patches were not clearcoated.
Overview:
