55 3 Speed Over Drive
50 merc
Pulled my new car into the shop and went to move it this morning and it is stuck in gear. The floor shift is sloppy and I can move it but it won't take it out of gear. It is a hurst shifter 3 speed. Any ideas before I get down to look at it would be great
Did you post this over on the HAMB too? They answered the question pretty good over there. Make sure both arms on the shifter line up with the hole in the shifter body, put the trans in neutral (dont run over yourself) then adjust the rods to fit.
Lowrider do you have the setup you show in your avitar. Mine is the same and a linkage slipped on the way home last night I may need some guidence with that too...lol
