It's not the cable that gives the accuracy, it's the tooth count on both the driven and drive gears as well as the axle ratio. As far as making up a cable to attach the 54 speedo to the aod, measure the length you need, then google speedo repairs and you will find someone that can make up what you need. You will have to do some trial and error on the gears. My guess would be to start out with the gear on the cable that would have been in the Lincoln. If the speedo reads to slow, find a gear with less teeth, too fast, more teeth. One tooth is usually good for about 5 mph. Gears should be plentiful at a wrecking yard, what you need can be found in most any c-4,c-6, aod or fmx, car or truck. Just make sure the angle of the tooth is the same, some are left and some are right
