I have converted my '54 Mercury from manual to power steering (necessitating a change to floor shift) and am having trouble getting the lights and turn signals working. All of the wires that run through the steering column have faded so the color codes in my wiring diagram are no help. I put number stickers on the wires and on the plastic junction block that they plug into before I unhooked the wires. Because the insulation on the wires was bad and got worse taking the steering column apart, I put shrink tubing on most of the wires. Having done this, two of the sticker numbers fell off of the wires so I may have gotten those two crossed up and plugged into the wrong holes in the junction block. Thus far I've only found one hot wire going into the junction block which I'm assuming is the one from the stop light switch (it's only hot when I put a jumper wire across the two stop light wires at the switch. I'm not sure yet which wire is the one off the accessory side of the key switch that runs through a fuse and the turn signal flasher. My wiring diagram shows that it doesn't connect to the junction block but runs direct into the turn signal mechanism. It might be the one that I grounded to the plate in the steering column shifter hub using the screw that goes through the plastic post on the plastic trim spacer under the steering wheel between it and the steering column/ shifter hub. This could be wrong but that's how I remember it. Electronics and wiring diagrams are a weakness for me; I know enough to get myself in trouble. If anyone can shed any light on this problem that I'm having I can certainly use the help!
Thanks, Scott
Thanks, Scott
