The end of the bar on both ends is pancaked out to hold the end bushing mount assembly. Do you mean somehow they will slide over those ends?? Pretty small hole to widen out that much.
I had to cut a slit through the back side and slip them on. Then I used 3M weatherstrip adhesive and glued them back together.
Put the sway bar and new bushings back on today. Everything looks good again!!
