Bob from Northport
I installed a new 6 volt electric pump on my 54 Mercury-256 engine. With it, I installed all new fuel lines. A brand new-not rebuilt-fuel pump. A brand new carburetor-not rebuilt. I have a fuel pressure gauge on the line near the carb.
The engine restarted and runs well. I installed a bypass around the electric fuel pump just in case. When switched on, the pump runs fine, but does not seem to pump any fuel forward, or build up pressure at the gauge. There was an old one on the car that did build up pressure to 3.5 lbs.
Can anyone think of a reason why this new pump does not seem to be pumping fuel?? Other than being a bad pump??
The photo is the electric pump I installed to the rear of the car on the frame.
