54 Mercury-box on firewall ID
Bob from Northport
Can anyone advise what this electrical box is on the firewall of my 54 Mercury.?? Seems like A HEAVY gauge wire running under the dash to the ignition switch I think..
Big wire to the relay to actuate the pull in coil on the solenoid. Then it switches over to a holding coil internally and the load goes down. I dont have a manual where I’m at, but I thought they were fed right off the battery (on my bird via the starter solenoid) and the coil circuit was thru the ignition. ?
Have you driven those overdrives before?
That sure looks like the OD relay box as mentioned above. Fuse tips it off. If it has 4 wire connections, I'd bet on it.
