53 to 56 steering columns
nick c
Are the steering columns in the f100, f250 and the f350 all the same from 53 to 56?
thanks nick c
The 56 column was shorter due to the dished steering wheel, about an inch. The obvious difference is between 3 on the tree or floor shifter. The 57-60 columns were shorter than the 56 again by about an inch or so.
Thanks for the reply. So do you think the size of the gear box is the same and would the bolt pattern on the gear box be the same?
thanks nick
From 53 to 55 the steering is the same and in 56 like MMB stated the column is a tick shorter but the steering box is the same.
