I would say it depends on why you use thermostats. If you drive in cold
temperatures and want heat in the car then use 180"s. If you drive mostly
April to Nov. then I would use 160's. In 90 plus outside temperatures 180
stats keep the temp ABOVE 180 all the time and the engine temp can go
as high as it gets, stats don't do anything to cool an engine they just make
them run hotter. The other thing is the type of stats used. You want one's
with large flow opening which are the Robertshaw 330-160 or 330-180.
Other modern type stats have small flow openings and restrict the amount
of coolant allowed to flow through the system. More flow equals cooler
running. The hi flow stats are available from Summit Racing and hot rod
shops as well as Bob Shewman
gadgiteer@aol.com G.M.
