Would like to overdrive a 53 pickup. Is the reason pu tailshafts are short because the trans is supported by the belhousing instead of tailshaft like automobiles. What about using a car OD trans with long tail shaft, shortning the driveshaft and adding some sort of support crossmember under the tailshaft to prevent wobble? I am guessing PU od trans are scarce as the hens teeth.
