W walter123 Junior Member Jul 5, 2011 #1 My tires are wearing on the outside and I am looking for some specs to give my mech. Thanks Walter123. I forgot to mention, the tires are radials... Last edited: Jul 5, 2011
51 MERC-CT Well-known member Jul 5, 2011 #2 Check this out---- http://www.secondchancegarage.com/public/422.cfm
F ford1 BANNED Jul 5, 2011 #3 prefered caster - 3/4 degrees, prefered camber +3/8 degree, prefered tow in 3/32 to 5/32"
F ford1 BANNED Jul 5, 2011 #5 could be or you camber is out making the front end run on the inside of the tires, check the easy stuff first check toe in and the toe out
