Britcheflee
So,
Thanks to your useful information - I removed solenoid and right away there was something not right - it just dropped right off the car - no twisting required to get it off - I bench tested and cleaned it up and it works great - when trying to replace it i noticed that the flat sides of the tip of the plunger align with the slot in the pawl - so when lined up to install bolts it would just pull right out with no connection. I used a allen key with the ball type tip to get in there and secure the pawl (I think) it did move a little but hardly anything - could not get the solenoid to secure to the pawl. Eventually tweaked the plunger so it would engage in the pawl or something inside - bolted it all up - tested (works fine) and went for a drive - no overdrive. So....unless there is something else I can do to tell if that pawl is moving I think that there is something amiss inside.
I have a feeling that previous owner had a similar problem thinking there was something wrong with solenoid as there is clear evidence that someone took a hammer or something and whacked the side of it a few times thinking that was what was not working - now I am thinking of removing the transmission but not sure how big a job that is. Any thoughts at this stage?
