53 ford starter draw?
buds56
My 53 V8 has a new wiring harness the large cables, a new ground strap from engine to frame,everything is clean.
The car runs great, but as a project in the bodywork stage I really haven't driven it any where.
This is my first 6 volt car, installed a new battery when I put the engine in this spring.
It starts fine the first time, runs great, charges.
But when I go to start it the second time a couple hours later it won't hardly turn over.
My question is how much voltage drop should there be when cranking?
If I load test the battery what voltage should it hold?
Thanks, Bud
Can't answer your question specifically, BUT...make sure that you have a LARGE ground strap (cable preferably) going from the BATT post to a BARE METAL (NOT painted) bolt somewhere on the cast-iron engine assembly. DD
But when I go to start it the second time a couple hours later it won't hardly turn over. My question is how much voltage drop should there be when cranking? If I load test the battery what voltage should it hold?
I don't know either, but here's the guy who can really help you.
Vern Davidson
Vern's Ford Flathead Shop
3478-1/2 F Rd
Clifton, Colorado 81520
970-434-898
flatheadvern@fordflathead.com
Vern was an enormous help to me regarding starters.
V8COOPMAN is right about the cable. The only thing I could add is that it is wise to attach the ground cable as closs to the starter as is possible. Clean attachment and large battery cables are a must for 6 Volt. The 12 Volt cables that you see on your daily driver are too small for a 6 volt system.
