Anyone familiar with the installation of a 53 Ford Center Grille installation? The part with the bullet nose? I have the center section figured out, and the attachment bolt above the parking light. From there it turns the corner around the outside of the fender. My grille bar doesn't seem to go back far enough to engage the bolt with the nutplate. It is probably an inch from the hole. Is there some sort of bracket that goes between the grille bar and the fender to make this line up? Seems to be the same on both sides. Thanks for any help.
