I am tuning my 53 flatty up and replaced plugs (gapped @ 30),wires,cap,rotor,points and condenser. set dwell at 28, timing @ 2 deg.
Now I set the idle speed @ 450. I got all specs from Van Pelts. This thing is barely running. seems a little slow. Got great vacuum. It has a little hesitation off of idle. Carb has fresh rebuild. New acc pump. With the hood closed I cant even hear or feel it run. Should I bump up the timing or idle?
I have acc pump set on the middle hole on throttle cam. Is this right?
