523 HP Y-Block!
georgewarren
Check out the Feb 2011 issue of Popular Hot Rodding's engine shoot out. 375 CI Y-block, 523 HP @6500 rpm, 477 ft/lbs @ 4,900 rpm. Uses Mummert alum. heads; when did these come out? Anyone have info or website for these?
ford-y-block.com
Also, in that PHR article, copy down the name of the guy who ram rodded the test. Ted Eaton is a guru who will help any dedicated Y blocker with just a phone call. If you are interested in these heads, you need to subscribe to the Y Block Magazine also. A wealth of exciting information.
Mummert's website
www.ford-y-block.com
You can see the heads and other y-block performance goodies, and besides that he is a super nice guy. Like Ted Eaton, he will help any y-blocker with advice or recommendations.
If you have a look on the Y blocks forever website there is a section there on them that has a lot of information, makes a good read. :) It has been a long road but they got there in the end with sheer determination.
http://www.y-blocksforever.com/forums/Forum11-1.aspx
The last Y I helped build certainly fell short of making that kind of HP, but did manage 383HP @ 6000rpm. I am no guru but cam/head/valve train design are certainly the key to making a Y block run. Here are some of the parts that went on the Y block I worked on.
Let's see, $2150 for the heads and $650 for the roller rockers..$2800..that's coming pretty close to what I paid for the Roush/Yates heads on my 408 stroker which flows 371 on the intake side and 294 on the exhaust.
Making over 500HP in any natrually aspirated motor takes cubic $$$$$ and a lot of thought, but in a Y block that is outstanding!
That looks like the makings of a nice build. I am interested in where you got your timing set, is that rollmaster?
thanks, Dan
