Hi. New to forum, new to Fords. First Ford is a 1952 F1.
Will the floor shift linkage from a 1950 F1 Flathead readily bolt on to my 52 F1 Flathead with a column shift set up or will there have to be a complete transmission swap or is there a column to floor shift kit already available?
Also, any overdrive suggestions, advice, options.. I'd like to cruze from Austin to the PigStand in San Antonio and an overdrive set up would really make the drive a much more pleasant journey.
