52 Mercury engine startup
oldford2
Continuing saga of my engine startup. Below is the last post on my previous thread that found a chafed wire under the distributor plate. That fixed the sudden shutdown but still starts first turn and idles great but past a very fast idle it stumbles and dies. I watched the timing light and it flashes till the engine stops revolving so it has spark as it dies, I took the teapot carb apart yesterday and everything was clean. I expected to find the main jets dirty but they were clean. Now I am shooting in the dark and will change the condenser this morning. Any ideas?
Thanks
John
"Ross F-1,
You got it. Chafed wire under the plate. Fortunately I had a spare. So that solved the sudden shutdown of the ignition. BUT, now when it is revved up it starts to stumble like not enough fuel. Looks like I have to venture into a teardown and check out the main jets. Thanks all of you for your help but don't go away. I am sure I will be back.
John"
There is a small vaccum port for the distributor, it was on mine, it gives a very little vaccum to work the distributor, mine was clogged, very hard to know this, I finally put a rochester carb on and it sure ran better!
If your using the stock loadamatic ignition, you need that carb with the correct vacuum port for it to advance. There is NO mechanical advance in the dizzy.
If you change the carb as you have done to a Rochester. These don't have the correct port. You must fit a different ignition, modify a sbc one to fit, or such.
Martin.
