Will a different pinion yoke that uses u-bolts to connect the u-joint fit the original pinion shaft to replace the original yoke that connects with flanges and bolts on the '52 Ford? I hope that is understandable.
Yes, trying to get driveshaft to fit in the balance machine. It is hard to find a driveshaft shop that can balance the driveshaft from a '50's Ford with the flange caps on the rear.
A simple trick you could try is a 3/8 flatwasher and a hose clamp. Make a mark as a starting point and put the screw of the clamp on top of the washer. Drive the car and rotate the washer till it smooths out. If you can get it to balance tack weld the washer in place. . Might take a larger or smaller washer.
most driveline shops have books that will tell you what u joint has the same size cross as yours does. Use the u-bolt style caps on your joint for the balance job, then switch back to re-install.
