52 Ford no heater
52 Ford
I do not plan on using a heater for now in my 52 Ford. What can or should i do with the outlet from the head and the inlet at the water pump? Should I run a hose from one to the other or just shut off the summer bypass and plug the water pump opening?
On my 52 Merc I just have a piece of heater hose to connect the two outlets and by pass the heater core. I don't plan on running it in real cold weather plus I don't know if the core leaks.
