51 Vicky Door Window Channel Felt
Lakesmodified
Just recently bought a 51 Vicky that’s been somewhat restored. All the window/door rubber/seals have been replaced, for the exception of the front window felt/seal that is up against the vent windows. Being that the window is “framed” in stainless steel, the seal needed us much larger than your typical felt seal. Checked with Shoebox Central, as well as a couple of the other suppliers, no help. Picture is for illustration only, as the dimensions are much larger. Unfortunately, the previous owner, discarded the originals, so I have nothing to go by. He finally installed some stick-on felt, but it’s not going to work. Thanks
Try Restoration Specialties in Pennsylvania. They used to have all sorts of window channels, even some hard to find ones.
