The generator belt has to be adjusted first, while the fan belt is loose.Reinstalling cooling system. Using NAPA belts 257516 and 257417. Unable to completely tighten the gen/water pump belt. Seems sloppy with extra play.
What should the belt deflection be when properly tightened?
Then the fan belt is adjusted.
The generator strap must be tight and holding the generator in it's cradle before any up/down adjustments using the center mount stud/nut.Thanks right now fighting the generator belt. Everything is loose-the fan is at the lowest on the bracket, the gen strap is undone and the gen bracket bolt as well. The question is what is the gen sequence - if I tighten the bracket bolt then it pulls the gen down. If I tighten the strap bolt first it limits moving the gen up to tighten the belt.
The gen/water pump belt is NAPA 257516 52in circum (OEM 8620) and is supposed to fit.
Am I doing something out of sync or is the belt too long?
Any thoughts?
Many of the modern belts are not the same exact width as the originals. This can cause them to ride deeper into the groove of the sheaves. The translation between metric and imperial inch fractions can make more than a bit of difference. I used to use Gates or Dayco belts but I haven't had to replace one for a long time so I don't know if any of them fit worth a dang anymore.
I take the generator out to adjust the cradle height. When I think I have it where I want it, I put the generator nose down on the front of the cradle, put the belt over the sheave, then pull the back down into the seat. It's easier for me to do it this way. Others may not do it this way so it's just a suggestion. That cradle is a heavy *******.
THANKS it worked after a few up and downs but eventually I got it to set right.
Don't over think it. 1/2" deflection on the longest span of the belt.Ok to keep the thread alive what is the best non tool method to determine the correct belt deflection? I used to use the old finger push/ruler method but wonder if that is still the best way to go? Like the old butcher's thumb on the scale to weigh things he hand a huge thumb pressure than most folks.
But really what is the easiest way?
thanks
