51 f1
51secondchance
Hi all does anyone know if ther are any clearance issues with a offenhouser intake and eddelbrock 4 barrel carb set up for my flathead, just trying to be prepared when the time comes
What do you mean by clearance issues ? I had one on mine and it cleared the hood , and generator . I had a Holley , but it shouldn't matter .
Some of the forums that talk about this type of upgrade mention that hoses and gen cause issues sometimes and thy mention a tall adapter plate for carb thanks fo the reply
The generator and fan is offset a little over an inch. This causes the fan to hit it's shroud, if you have one.
Hmmm.......mine has a shroud , and the fan didn't hit it .:confused:
I had the Edelbrock manifold that Speedway sells . It was on my truck when I got it , I installed the original manifold & carb because I wanted to take the engine back to stock . Also , the stock distributor's vacuum advance didn't work good w/the aftermarket Holley carb. The truck runs much better , now . :)
