K kjvma131 Member Apr 29, 2020 #1 Hello all. The backing plates on this f1 are apparently right and left. Plates are bare back from the powdercoater. No part numbers visible. Any way to tell the difference? Both look the same to me. Thanks Sent from my SM-G960U using Tapatalk
skidmarks Well-known member Apr 29, 2020 #2 Looking at the outside wheel cylinder leans toward 1 o'clock. On backwards the hose interferes with the top of the kingpin
K kjvma131 Member Apr 29, 2020 #3 Thanks Skidmarks. That would have sucked to do it twice. Sent from my SM-G960U using Tapatalk
skidmarks Well-known member Apr 29, 2020 #4 Should have said the right leans to 1 o clock and the left to 11 but its easy to tell holding them up
JSeery Member Emeritus Apr 29, 2020 #5 Aren't they marked with an R and L on them? I would have to go look, but fairly sure there is an R or L stamped on the inside of the backing plates. Last edited: Apr 29, 2020
K kjvma131 Member Apr 29, 2020 #6 They were pretty beat up before powder coating. Couldn't see anything. Thanks for the reply. Sent from my SM-G960U using Tapatalk
