hulleywoodworking
1951 Ford F1, 239 flathead V8, 3 speed light duty remote shift transmission. Engine and transmission completely rebuilt. Newly rebuilt clutch, pressure plate, and throwout bearing from Fort Wayne Clutch.
I recently posted a question about the correct assembly of the synchronizer assembly, which was answered by Mac Van Pelt. I had pulled the transmission to remove and fix the synchronizer. Got it all back together and installed. Started the truck with the drive shaft still disconnected and ran through the gears.
So finally, my question. When the transmission is in neutral, the output shaft spins. I can stop it with my hands, but it takes a fair amount of pressure to stop it. When I push in the clutch pedal, the out put shaft completely stops. I have the clutch pedal free play adjusted to 1-1/8".
So what's going on here? Something's not right, I just don't know what.
