Mike51Merc
Re: ‘50 Won’t Go Into Gear - Help
Regarding disabling the ignition, I highly doubt that car is going to start after sitting a long time by bumping the starter in gear.
If you're worried about it taking off, hold the brake pedal when you bump the starter and/or open the garage door and put in in the appropriate gear so if it starts it drives out the door.
Jacking the wheels off the floor defeats the purpose. You're trying to force the clutch free from the flywheel. If the wheels spin in the air that will not happen.
Lastly, yes disassembly and inspection is the best way to diagnose and repair, but there's a better than fair chance that you have some flash rust on the clutch surfaces that has caused some sticking. Trust me, I've been there and fixed the problem in 2 minutes.
