My Borg Warner OD unit whines while in the locked up, overdrive position. Engages and disengages fine and quiet as a church mouse while in freewheel mode (overdrive electricals removed temporarily). Today I removed the trans and knocked the tailhousing off. I don't see anything wrong. Rollers are smooth, the three little planetary gears look good and turn smooth, no shavings in the drained gear oil. I was running 90W oil. The tailshaft drum where the planetarys ride in also seems fine and where the rollers ride in the drum is smooth with no pits.
Any ideas?
Any ideas?
