cadillac512
41ford1
Your attachment shows the wiring diagram for the temperature sensors. On it the diagram shows that contact opens at approximately ? temperature. I am unable to read what the temperature is. Do you have the original to tell me what that number is?
I have a 1950 shoebox and have been running a actual temperature gauge for each head after a rebuild. The temperature runs anywhere from 190 to 210 degrees on each head while driving. I have now installed new factory sensors and it is running in half way between cold and hot. I haven't run it much since. I was wandering at what temperature the double contact opens to send it to hot.
The attachment shows the double contact opening at 204F. Enlarged, it's blurry but readable. So 19Fordy is correct and so is his sender. My '41 Merc with original senders and 180 degree 'stats runs 185-190 degrees on the heads in warm weather and the gauge reads just under 3/4. In cool weather it might run between 1/2 and 3/4...right on the thermostats' beginning opening points. I believe my gauge will read right on the HOT mark at approx 212-215F if I disconnect the double wire sensor and run just the single.
Terry
