50 f-1
Jimbo
Well here it is. I finally got the front clip on. Pretty happy with the look, would like to get the rear end down A little bit and it's geared to low. Would like to be able to cruize highway speeds. But that's another project.
Looks good! Be sure to install all the air deflectors up front in order to keep your temps down.
9" rear from a 57-72 half-ton will get you down the hwy at speed. Almost bolt in operation and a 3.50:1 rolls my 48 at an easy 62-65 and can bump up to 75 as needed. Yet starts off easily - sometimes in second gear.
If I ever swap this one I'll look for 3.25's.
Nice solid looking truck!!The stance will be great once you drop the rear.What did you to to get the front dropped?You may want to run a fan shroud also.
Joe
Good looking truck,
I installed the same rear end from a 72 F100 and it REALLY helped the drive ability. The only thing that gave me any difficulty was the u-joint (big cup and small cup dilema) but a good parts store, heck a fair parts store should be able to handle that one!!
Just take in the old cups that fit both the yokes and they SHOULD be able to fit one.
Did I say a GOOD looking truck??
Oh I did but it's worth repeating
Looking good. I went with 9 inch and t-5. Posie springs in the front and back brought mine down to where I like it. I also went with 15 inch rims and if I did it over I would stay with 16 inch. I think they would fit the wheel wells better.
Pete
