Ford did have a different shifting mechanism than the Mercs but they still had an S-shaped bracket at the bottom of the steering column that held the switch in a position where the 1st/reverse lever would depress the switch button when reverse gear was selected. Instructions were supplied with the 8A-18275 back up lamp kit for 1949 thru 51 vehicles with standard shift.
