Hello,
I'm new to the forum, and have recently acquired a 49 F47 pickup.
(An F1 to my American neighbours to the South) I live in Calgary, Alberta.
This is my first post. Sorry it's in the form of a question, rather than one of assistance.
I'm hoping someone may have a suggestion that helps solve my brief overheating issue. I noticed the driver's side engine bank seemed to run cooler than the passenger side, so I wondered if there was a thermostat on that side. Upon draining and removing the thermostat housing I found that the thermostat was there, but it had slipped down when it was installed, leaving an open situation. It was obvious by the mark left on the gasket that it had been installed that way.
I replaced the thermostat (on both sides) and made sure it remained in place by using some gasket glue. Now I have the opposite problem with the driver's side, running up to 200 + before the thermostat opens. (160º). I monitored the temps with an infrared thermometer and the head reaches 200 - 210 and then the thermostat opens.
The gauge also gets up to high. As soon as it opens the temp quickly drops down to the normal range and the head temperature pretty much matches the thermostat range.... about 165º
I have checked that it is not in backwards and have also installed a new one, but the problem persists. I have noticed that the temperature right near the housing seems to stay cooler than the rest of the head, so it appears that the thermostat is not getting the high temps nearby. Eventually, it gets warm enough at the top front of the head, thermostat opens and it seems to behave fine after that. I am hesitant to run it much more, as it is reaching an overheat situation, although only for a couple of minutes. Also at this particular time I have straight water with a flush agent in it, so it concerns me a bit more.
I have wondered if perhaps this might signal a water pump issue? I'm not entirely sure how the water pump functions with a closed thermostat. It's curious though as it is the top front of the head that seems to stay cool. It also seems to be an original pump, as it has the oiler cap on it.
I thought of trying to find a 140 or 150º thermostat, but that would be kind of a band-aide solution.
I might add, I drove the truck about 250 miles to my home after purchasing it.
There were no overheating issues, but it did hit the 3/4 mark on the gauge at one point after climbing a long gradual incline of about 10 miles at highway speed (55-60 mph). Aside from that, the temp never got much past the halfway mark. Ideally, I would upgrade the cooling system with new pumps and a better radiator, but I am puzzled by this condition.
Sorry for the long initial post, but I wanted to provide enough clarity and related background info.
I'm looking forward to being a forum member.
All the Best
Wayne
All the Best
Wayne
