Mad Mux
The wiring on my '51 was in pretty good shape, with the exception of the harness between the headlights and signals, etc. That was cheap and easy to replace. I had a couple of frayed connections (at the terminal end of the wire) that I repaired with 3X shrink tubing. It's big enough to slip over the terminal, but will still shrink down nice and tight. Sometimes two layers work better. It's expensive, but it's out there. I wouldn't go out and try to repair a crapped out harness that way, but for just a bad terminal or two, it works great.
Great tip, I'll try that. I need good quality butt splices for a few wires, I assume NAPA would have good ones?
