49 Mercury Trim clips ?
1949mercury
I'm looking for the trim clips for the chrome pieces that run along the windows on the left and right side 3/4 x 3/4 anyone know where to get them ?
Thank you
If you do a flea-pay search look for Belt Trim or molding of appropriate year Mercury. The 3/4" spring clips should come up. Now if its lower door trim then look for that.
A lot of the late type replacement stuff is bolt on so that would be difficult if not impossible for belt trim pieces. The door trim pieces only have a few bolt on clips but they are located where you can get to them and there are only a few of them per side.
Ok thanks. I'm looking for the trim right under the window not the trim on the door.
I will look at restoration specialties I have got some stuff from them before.
I have the trim clips with the dot of rubber to seal the hole or not ..LMSGDS1951@MSN.COM
the rubber dot pcs are not shown..however in a box on a shelf..ALSO I have new door sills for 49/51 merc and an almost perfect hood can del that next week at charlotte meet
