Joeyv
I’m having a problem putting the steering wheel back on my 49 Mercury. The steering wheel has been off for a while. I did some unrelated work on the steering column. Now that I putting it back on, I must have parts in the wrong place because I’m unable to tighten the steering wheel down as far as it needs to go. The threads on the steering column barely clears the nut that holds the steering wheel down, and there’s a gap between the steering wheel and the gearshift housing. When assembled as shown in the pictures I have included, the horn does not work because there’s no contact between the horn ring and the horn contact because of the gap. Can anyone identify what I have assembled incorrectly, or show me a picture of how it should be assembled? I’ve looked in the documentation I have and it doesn’t get down to the detail of the horn ring assembly and spring fits on the steering wheel. The steering wheel fit fine and the horn worked perfectly before I took it off. Any help would be appreciated, thanks.
