49' Merc clutch fork pin removal
timdhawk
I did a search and saw some posts for older models, but wondered if there was any difference with the 49' Merc pin? Do I still need to file or drill the head off the pin then punch it our?
thanks
I think that there is a bit of a countersink at the end of the pin, drill into the pin so that you're below the surface about 1/8"- Then use a hammer and punch to drive it out. Replace it with a solid pin or bolt- don't use a spring type hollow pin- it will collapse.
Guess how I found that out!
Karl
