49 Ford Sedan floor
Pa Joe
Talking to a friend that has a 49 Ford tudor sedan about changing out the ******. I thought they had (like many cars back then) a panel above the ****** in the floor that was removeable. Before we get started on this, I thought I would ask, is there a removeable panel in the floor or is the floor solid? Thanks in advance
Should have a removeable panel but I don't see any need to remove anything from the floor to remove the ******. Eight bolts on the crossmember (4 each side) 2 that hold the ****** to the crossmember, 4 that hold the ****** to the bellhousing, speedo cable and of course the drive shaft. Don't forget to support the rear of the engine. Forgot clutch linkage and shifter rods.
