49 ford foxcraft fender skirts
Can't help, but if memory is correct, a friend found some self adhearing weather stripping at Ace Hardware & it worked pretty good.......
does anyone know where i can find new seals ? the ones from mac wont work on the foxcraft skirts
Check this out---
https://www.ebay.com/itm/171606404572?hash=item27f489eddc:g:4bYAAOSwjt5afNm3
Suspect that it's the same as Mac's
The barbed end has to be pushed/forced into the channel like this---
470570
thats the same part #i dont think there anyway to make it work i have the ribbed set also and i dont think it would work on them either... guess ill have to put them on with the cracked and shrank orig ones :[
While these company only have generic seals, they might have something that works. Restoration Specialties in PA and Metro Molded parts
There used to be a lot of different rubber extrusions made for all sorts of purposes. I don't know what is currently produced but there may still be something out there that can be made to work. I've used a belt sander to "trim" edges from extrusions to get a fit.
