Sorry but a 6 or V8 in all case's one wire from gauge goes to a make and break sender found on the left head. When cold the left sender points are closed shooting a signal to the right sender to the dash gauge. Ok, so simple a V8 has a split cooling left and right or they would not have two water pumps. All temp. signals come from the right one wire
sender now if the left head gets up to hot, this sender opens meaning an open line to the dash >>>>HOT another word is removing dender wire from the dash the needle goes HOT. You ground that wire with jumper needle goes to cold so thats good. So you need a one wire sender. And then I have a couple trucks with a 337V8 and these have only one , one wire sender (not too like smaller V8s.)
