48 Horn Problems
48fordconv
My horns don't sound good, can they be adjusted. Also the thin metal pieces between bracket and horn are weak and a few broken. can you buy new pieces. Thanks
If the mounting structures are deteriorating, the ground path is also deteriorating. You may have to find some old horns at a flea market or flea-pay and swap the mounts out. They could be repaired but you will have to drill rivets & fabricate metal pieces to do the job.
While we are on the subject of horns and their repair, Does anyone know the value of the big black condenser inside the horns? How many mfd?
