FortyNiner Well-known member Mar 28, 2024 #3 For vehicles produced in the US, on the top of the driver's side frame rail between the radiator support and the steering box. The stampings are not deep, so use a scotch-brite pad to remove the typical crud as you search. Last edited: Mar 28, 2024
19Fordy Well-known member Mar 28, 2024 #5 This will help: Same as a 47 Ford http://www.vanpeltsales.com/FH_web/1939ford-project-teardown-13.htm
65f100 Member Mar 29, 2024 #6 very god thanx for replies!..Ill look there again when its off the trailer and remove front clip
TJ Well-known member Mar 29, 2024 #7 Most often I have found that the 46-48 Ford ID number is found near the front crossmember.
