48 Ford passenger tail light wiring issue
AD1948Ford
In need of some help. I recently installed and hooked up a new dash dimmer switch, license plate light and hooked up the sending unit. In doing so, i unhooked the tail light wires and re-routed the wires in the proper location. Prior to do all this, my tail lights and brake lights worked. Now I have headlights (normal and brights), brake lights but no dash lights, license plate light or tail lights when the switch is pulled out.
What could be the issue? Bad connections? Bad ground on tail light housing?
Any help would be appreciated.
Aaron
Looking at the wiring diagram the tail, license, and dash light all come from
the black wire on the light switch. That's where I would start looking.
Thank you, Bob. You were spot on. One of my connector sleeves must of gave out. I replaced it and boom, everything works.
