Good morning,can you tell me the correct valve lash settings for this motor? My book has 2 listings,they are .010 .014 .017 .019 ?Also it does not say hot or cold setting,let me know ,thanks
1949 and early 1950-
Intake: .009-.011
Exhaust: .013- .015
Late 1950 to 1951-
Intake: .013- .015
Exhaust: .017- .019
All settings are COLD
Late engines with the late camshaft (OHA-6252 ) will have the letters "OH" stamped on the right side of engine block directly above the number 3 intake port. Also, the letter "O" or "B" is stamped on the forward end of the camshaft.
Your 1948 should be set at:
Intake: .009-.011
Exhaust: .013- .015
I assume it is an "H" series with adjustable valve tappets.
