48 F1 signal switch
porscheman7@gmail.com
Hi everyone,
I am new to the form. I am from Ajax Ontario in Canada.
I have a 1948 F47 which is our Canadian version of the F1.
I found a used directional signal switch and am attempting to hook it up. There are four wires. I understand where three of them go, but I am uncertain where to hook up the yellow wire. It goes inside and lights the bulb that shows you, your signals are flashing as it flashes along. However, I am not sure which terminal to hook it up to. I have a two terminal, 6 V flasher, should I be using a three terminal flasher. Not sure where to find one in 6 V thank you for any of your help. If any of you have a schematic to forward to me, that would be great. I will try to attach a picture of my.
Also, there is a sliding switch on the top, which I am not sure what it’s for. Grab someone can enlighten me?
